Mike McLane
OK. I know almost nothing about electronics, but I put together a preliminary layout for an AB763 circuit board based on a number of schematics I pulled up and am hoping I can get some coaching on it. It has an added Mid control as well as an EQ Lift component to it. The big issue for me is the power supply which I'm powerless (ha ha) to design. We can delve into power if I get some basic interest from you guys in debugging this circuit layout. Also, I forgot to indicate the value of the pots, but they're standard Fender values (Mid pot is A10K, EQ pot is A250K) The components show are to scale (looked up the specs) and they are shown mounted on a 2.25" x 2.25" board. Working out the enclosure and location of the pots and tube socket would come after finalizing the circuit board and power supply. Had a couple of specific questions denoted by asterisks 1 & 2 (don't worry with 3 for now). #1 - Most amps have a 120pf bright cap in the area shown on the Gain pot. Should there be one left there or should it be moved to the Volume pot? Also, as guitar players most of us install a treble bleed circuit (cap & resistor in parallel) across our volume pots to accomplish the same thing and it works much more seamlessly than this all-or-nothing approach of the switched cap? Why can't we do that here? #2 - This would be a footswitch instantiating the EQ Lift, the EQ pot determines the amount of "lift". That results in a marked increase in volume, but Kingsley puts a pot on his pedals to control that. Could that be done by placing a standard volume control pot in between the Mid pot and the foot switch? If so, what value?
