Mike McLane
1. What type of pots do you use? I would guess standard 12mm would take up quite a bit of depth and hamper placement of the Sig board relative to the PS to some degree.
2. Any rec's on tube socket brand/type? How do you physically secure it? Kingsley appears to just use brass standoffs bolted to the wall of the enclosure.
3. How do you physically secure the circuit boards. Particularly given that you want the voltage regulator to be affixed to the enclosure for heat dissipation. I don't notice any protruding screw heads on the exterior surface of your units that would indicate "bolted in" standoffs so I'm guessing its magic?????
