chirchmins
Hello,
Just finished a Tweedman and having some trouble.
toggle switch in "stock bass" mode is very quiet. "lead" mode is barely unity even with gain and vol pots maxed. No signs of gain...
Treble pot is non-functioning too.
pres. trim pot works, all other pots work - except treble.
could these symptoms be connected?
smd SMMBF4393LT1G from mouser with ordinary soldering iron
reflowed solder on treble pot and transistors. - no change
alligator clipped a new pot to the bad ones leads to see if maybe the pot was bad but still no change.
happy to provide voltages or more images if asked.
Anything helps - thanks so much.
build docs here
build docs here
