mybud
- Build Rating
- 4.00 star(s)
Ok, herewith my first build report for 2026 and a long interval since the last because I’ve been down the modular synth rabbit-hole for the last couple of months. I used a trio of AC128s (Q1 164, 1.284mA, Q2 167, 0.92mA, Q3 118, 0.72mA). After breadboard testing, this particular combination seemed to work best.
Something quite weird happened when I first fired it up in its housing. There was a typical ‘magic smoke’ smell within seconds. I disconnected it and naturally assumed the worst (blown charge pump or diode, AC128s gone west, what have you). Having managed to assemble everything in my initial optimism, I dreaded having to disassemble and troubleshoot the whole shooting match.
I then tested the protection diode and charge pump and got plausible voltage readings and retested the audio, which worked as before. Really peculiar, but no further panics: all working according to plan. Perhaps the pedal gods were trying to amuse themselves at my expense.
How is it? A fairly typical TB but a bit more versatile perhaps. I’m not over-enamoured of fuzz boxes generally but this takes the classic TB a bit further. I think
I’m going to leave it running all day, just to determine that the weird behaviour above has now truly corrected itself. Wouldn’t want to burn down my workshop inadvertently.
Thanks for reading as ever and best wishes for successful builds to you all.
