Another coincidence. I also have a Burny Les Paul (but mine is a John Sykes signature 1986)Quick demo, no EQ no mastering.
Guitar Burny Sustainer (Les Paul) => Ultisol => Unicab => Reaper DAW
Not sure where @Dali got his, but I use similar and just got them from Amazon. Probably not the cheapest tho.
mxuteuk 30 Pairs 26 AWG 2 Pin Mini Micro JST 1.25mm Connector Plug Cable Wire Male Female with 100mm Cable JST -1.25mm: Amazon.ca: Tools & Home Improvement
You could use those also, pretty cheap: MALE / FEMALE. One side is not soldered to wires, but I've bought a set some time ago (from Amazon, before I realized that Tayda had them) and the male connectors where also without wires, but cost me 10 times+ more!Great looking build. Where do you get the connector/wire that you use for the DC jack?
As a plus, the male work great on the DC jack breakout board for multi-pedals, or for the SPDT on relay boards
Currency conversion ? 15.99CAN$ vs 10.99USD$, however you are right... 45% is a steep conversion.Good to know that Tayda has them. I will probably keep my Amazon order just because I don't think I'll be doing a Tayda order for a little while and have a few pedals in the pipeline. They were less expensive on the US Amazon site as well (though not nearly as cheap as Tayda, of course). I think that Canadians may be getting hosed by Amazon.
Great work, great demo. I see you went with the French spelling.
