I'm playing around with the Pythagorus schematic and trying out a few ideas for modifications, namely some additional layers of splitting and blending with other signals. https://docs.pedalpcb.com/project/Pythagoras.pdf
Is this description generally an accurate understanding of everything going on with the two TL072s?
IC 1.1 - High impedance input buffer, ready to be split into a dry and a wet signal to be blended back later
IC 5.2 - Another non-inverting buffer to bring the gain back up on the wet signal after going through the fv-1
IC 1.2 - Summing op amp stage for blending wet and try signals, also volume control via the feedback
IC 5.1 - Uses the last op amp slot from the second TL072 to to flip the phase back form the previous inverting amplifier and do a bit more conditioning before output.
Am I missing anything? Way off anywhere?
I'm wondering if it's viable to mess around with those last two stages to turn one into another split stage and the second into a blend and volume stage, or whether it's time for TL072 number three haha.
Thanks!
Thanks!
