Pin 5 of ic3 seems to max out at 3.33. pin 3 of ic1: what could cause that ? Non inverted input 1 so is it the chip itself that could be bad ? R3 is 10k than the cap . Could something "drain" the power ?Something is amiss at pin 3 of IC1, it should be around 4-4.5 like the others. It will read a bit lower if you don’t have a meter with a 10M impedance, but not that low.
Also pin 5 of IC3 but it probably varies with the size control.
