Hello PedalPCB forum,
Just finished building my Unison Double Tracker, but when turned on there is no noticable effect in neither setting. When the 'Mix' pot is turned all the way up (to effect-only) the output signal is zero, suggesting that the dry signal goes through fine but the processed signal does not.
The Spin FV-1 seems to work properly. I tested this by switching the processor to the internal 'demo' programs (flanger-reverb, tremolo-reverb etc.) and that worked great. To make it an Unison Double Tracker and not a FV-1 demo pedal , the external mode needs to post to the EEprom, which it does, but the signal falls flat here. It seems like the EEprom is not coded correctly or in some sort of muted mode?
Hopefully some of you pros can help me out!
