- Build Rating
- 5.00 star(s)
Unison Double Tracker with the Stereo Mod in matte black. Sounds amazing, probably my favorite build to date. Used the pin 1 tl072 mod to make it stereo, except, I went through the front and jammed the lead of the cap into the socket the same time as the tl072. No soldering, works great. Used a 4pdt so that the bypass is also stereo, and the ring and tip both have a bypass signal. Highly recommend this build, especially if you play with a dual amp setup.
