Using LT1054 in place of 1044?
sethwitz
Hi all, I hope you're having an easy start to the holiday season! I'm currently wrapping up a Projectile Overdrive build and I just realized I don't have any 7660s or 1044 charge pumps. I do however have a few 1054s on hand. Can I use that as a drop-in replacement for the 1044?
Thanks!
Yes you can but lift pin1 as it is not a boost pin as in the 1044. Leave it unconnected on the 1054. The pcb should have pin 1 and 8 connected as I can see on the schematic.
Oh ok, pin1 is for also for shutdown btu I thought it's to shut it down above a threshold... "Pulling FB/SD below the shutdown threshold (≈ 0.45" from the datasheet. So then just replace :-)
