Hello everyone,
I have problems getting the Valhalla Pedal Kit to work, and I don’t know what else I can try to fix it.
I have some experience with circuit boards and electronic components, and I’ve successfully assembled a pedal kit in the past. However, I’ll admit my soldering skills are a bit... well, let's say, improvable, as I have rather shaky hands. On the other hand, I’ve successfully soldered many projects before and never had problems with cold solder joints or similar issues.
I’ve attached a few photos of my non-functioning circuit board to this post.
When I plug in the pedal, my amplifier doesn’t make any sound at all. It seems like there’s no connection between input and output, both when the pedal is on and off.
The small LED, however, lights up red, and on my multi-meter, I also see ~9V.
What I have tried so far:
• Checking each resistor to make sure it’s the right one in the correct place.
• Checking if the potentiometers are in the right spots.
• Checking if all capacitors are correctly oriented.
→ One electrolytic capacitor was not correctly oriented, but I have already replaced it with a new one in the correct size and orientation.
• Checking all diodes.
→ Since I wasn’t sure if I had placed the very similar-looking Zener diodes in the correct spots, I de-soldered all the diodes and soldered in new ones with the correct part numbers.
• Checking if any of the pins on the input and output jacks are touching the case.
• Re-soldering the worse-looking joints visible in the photos, where one could suspect there might be bridges where they shouldn’t be. According to my multimeter, this wasn’t the case, but I did re-solder some of those spots anyway.
None of this has helped.
Does anyone have a tip? What am I doing wrong? What should I try next?
Thank you in advance for your efforts in helping me.
