Hi all!
I posted about this on the Madbean forum but I'm still trying to resolve a couple issues. In summary:
IC1 with OPA134 installed
1 8 (should be -8.4)
2 0 (should be 0)
3 0 (should be 0)
4 -8 (should be -8.4)
5 0 (should be -8.4)
6 0 (should be 0)
7 8.3 (should be 8.8)
8 8 (ignore)
Thanks!
- My initial build was completely silent when engaging the effect. I tracked this down to a solder joint that I had missed.
- After resolving Issue 1, I was still seeing screwy voltage readings on IC1 (the OPA134 output stage amp). At this point, I was getting sound through the pedal but the envelope effect was not working. I ended up swapping in another OPA134 from the same Mouser order and it exhibited the same symptoms. Only after I swapped in a CA3130EZ (the only other single op-amp I had on hand) did the voltage readings mostly resolve (with one exception described below), and the effect mostly began working.
- Even with the CA3130EZ, I'm seeing ~4V DC on pin 6 (output). I think this is the cause of some nasty scratching noise when I turn the level knob.
2 0 (should be 0)
3 0 (should be 0)
6 0 (should be 0)
8 8 (ignore)
Thanks!
