SOLVED Vibrobot volume drop
chinaski
Hi all,
Just finished a Vibrobot build and it works, except for a marked volume drop.
I’m used to tremolo effect so I know it’s not a trick my ear is playing on me.
Is there maybe a resistor value that is more important than others as far as being out of spec or a change someplace in the circuit to make up for the drop?
Thanks in advance!
Make sure vref is 1/2 Vcc.
Make sure you have no cold joints/reflow if needed.
Increasing R4 and R8 a little should add some volume but you don't want to add to much or you may clip the opamp.
But you should have a gain of 2.1 or so already.
Note, this pedal may not drive a long cable well due to no actives after the blend control. Maybe try a buffer/boss pedal after it if it's last in chain.
