sticky1138
I built the VIIB a while ago and finally got around to messing with it. It sounds great but seems to have a switching issue. True-bypass mode functions as it should, but in ramp mode, some weird things happen.
Every once in a while, when holding down the footswitch, the LED will blink rapidly between the two colors. Then the switch function flips so that holding it down passes the clean signal and letting go activates the effect. This happens without warning, usually after a few holds of the footswitch. Sometimes it will flip back and function as it’s supposed to.
Any ideas on what might be happening?
