ivandelado
Hello y'all this is my first post...
well, a few weeks ago I started this building, I used to build pedals before coming to the USA. I got the parts to make this right and since it was a pedal that I´m going be using a lot (it is a double pedal), I decided to get "good parts" well I soldered the smd j201 and the other stuff and I was using the 3PDT order switch but as soon as I turn it on the pedal a huge static cracking started making noise and also i couldn't pass half noon on the pots because a loud whine started going...
My first though was the j201 since the other building was full of jfets that needs be biased but I saw the schematic and it looks like it is not haha, at this point I've had removed the smd j201 and I tried a th j201 but no luck, I know it works because I used the same jfet in the other building and it was passing the sound but it is not doing the same in the virgil, then I tried to solder again other smd j201 but no luck.
Then I saw this post on reddit and it looks like my first issue was related to this order switch but so I think I'm not going to use it...
Order switch on reddit
Can anyone help me identifying the issue?
Also yeah the 4558 in the picture sucks, I had some rc4558p from Texas instruments.
Also I don't know if the flux could also be a problem, help please!
P.S. english is not my first lenguage and I don't have a lot in the USA so please excuse me if I'm not able to express myself.
