megatrav
Hey folks,
I have been experimenting with using water slides on a recent build. I am using an inkjet printer and doing a couple heavy coats of krylon clear so that the color doesn’t run.
The color isn’t running, however. No matter how well I try to flatten it on the enclosure, the sides and corners aren’t staying flat. Is there a method I should try or do I need to add more clear coat?
The lines aren’t hanging over as you can see in the image.
Any advice is appreciated!
