DEMO Weeble [Phase Vibrato]
Aleph Null
The Weeble is my take on Tim Escobedo's Wobbletron, a true phase vibrato. Phase vibrato has a depth and dimensionality that I don't hear in delay based vibratos. Because the amount of pitch bending is frequency dependent, where you play on the neck, pickup selection, and tone controls can all effect the depth and quality of the vibrato.
I used "sea breeze" for the enclosure color and a Japanese wave theme for the pattern.
I used through-hole JFETs because I had them, but the PCB will accommodate surface mount as well.
I've added a second phase stage which allows for extra depth as well as more vibrato at slower speeds. The LFO is left unchanged other than allowing half the minimum speed of the Wobbletron because it's already giving about as much as it can. The capacitors in the all-pass stages really do make a difference in the tone of the effect. With Throb and Chop off, you get a magnatone kind of sound simillar Tim's design, but with much more depth available and the option for going half as fast. Throb changes the knee frequency of the first all-pass filter. When engaged, it can get a little into Univibe territory. Chop changes the knee frequency of the second all-pass filter. This is more dramatic a change than the Throb control and almost sounds like tremolo at faster settings. The first half of the Depth control provides a smooth warble. Beyond that, it starts to get choppy at most speeds.
Despite being close to unity gain, this is not a high-headroom effect. Sending the signal through two JFETs limits the dynamic range. For most guitar signals, this shouldn't be an issue, but this won't handle a proper line level output. That said, when it does saturate, it's pleasing; it sounds like a cat purring. Overall, I'm pleased with the range of wobbly sounds this circuit makes.
Here's a demo:
As always, if anyone would like to build this, I have extra PCBs. Just DM me.
Sounds super nice! Do you happen to know your fet measurements?
I don't. It shouldn't be very critical in this circuit anyway: since there is no dry signal, there's not really a need for calibration. I did include a trim pot to adjust out the dead spot at the lowest depth settings.
I like the sound, but that’s some pretty gnarly thumping going on.
I put pull down resistors in place to prevent popping when using the switches, but there's nothing I can do about the sudden change in frequency response if you are somehow flipping the switches and playing at the same time. That is an artifact of the demo process and not something that would really happen during normal use.
...unless you mean some of the higher depth settings. I decided to opt for more available depth so that more vibrato would be possible at slower speeds, but that means too much depth is available at faster speeds, thus, the possibility of thumping. Basically, I had to choose between making it ugly proof or maximizing the control ranges, and I chose the latter. That said, there are some "ugly" settings for clean guitar that sound cool when pushed into an overdrive or fuzz.
It was the thumping that matched the led. I guess it was the depth thing.
I was watching this demo again. I miss that kind of modulation, so I’ve been looking at the original Tim Escobedo schematic, and I’m wondering if the original sounds a bit too subtle. I redrew a verified veroboard layout to make it smaller for a 1590A enclosure. If two stages sound much better, I’ll design a brand new layout for a larger enclosure.
There are two problems with the original in my estimation; first, one stage of phasing doesn't produce very much vibrato depth; second, the JFET has pretty limited headroom and will distort with any kind of proper strumming.
Part of the reason for the voicing switches in my design is to overcome the central limitation of phase vibrato, which is that it is frequency dependent. Changing the capacitors changes the knee frequency of the all-pass filter which changes the frequency at which the vibrato is strongest. Using mismatched caps means there are two frequencies at which vibrato is most prominent. But it's an illusive effect, change the pickup or move to a different spot on the neck and the "best" setting can change.
I've actually redesigned this circuit to use LDRs instead of JFETs to get an acceptable amount of headroom. I'm planning on doing a separate build report for that some time this week.
If you're going the vero route, I'd suggest looking into the Magnavibe. It's another good point of reference.
