steviejr92
Authorized Vendor
Thats beautiful!Seymour Duncan APH2s CTS pots and orange drop caps. 50s wiring completed.
Thanks. The two benches were birthday presents last month. Gotta get the Raspberry Pi I am using as the computer mounted to the back of the monitor to clean things up a bit and I really need a new electric circuit added. I have no outlet in that corner, so I have an extension cord running into another room. All a work in progress.Really liking your set up here.
Nobody said we could use Legos in our builds! Im in!![]()
It’s certainly an inspiration to have a setup like that! As is, it’s much better than what I have going onThanks. The two benches were birthday presents last month. Gotta get the Raspberry Pi I am using as the computer mounted to the back of the monitor to clean things up a bit and I really need a new electric circuit added. I have no outlet in that corner, so I have an extension cord running into another room. All a work in progress.
As for the Legos, I am not using them for pedals, but knock yourself out.
The first computer I ever programmed on. It had one Error code: "stop check". The output device was a *pre-typeball* typewriter....Finally got back to the Terrarium. Looking forward to learning how to program it.
Looks familiar, is that a 1620? Can't quite read the model number.The first computer I ever programmed on. It had one Error code: "stop check". The output device was a *pre-typeball* typewriter....
Enclosure arrived, managed to get it all drilled. Hopefully can wire it all up before I leave in a couple days.
"Build a pedal on 'vacation'," I said;
"It'll be fun," I said...
Baxandall tone control module for an upright bass preamp pedal build I'm in the middle of:
Bass and mids only, I do treble in a separate module the vast majority of the time. Switch is for mid frequency, 420-700-1.2kHz in this case.
Got it all put together, now it’s time to visit some repos and figure it all out.
Lots. I just need to figure out how to start.What does it (or CAN it) do?
High on my interest list, for sure.
Like the Dutch color scheme on the wiring.
Yup, just a few days ago I was cleaning out the garage and found the "Programming in assembly language on the IBM 1620". I thought about tossing it, and instead put it back on the shelf.Looks familiar, is that a 1620? Can't quite read the model number.
Cause you never know when that might be handy... like to throw at a rat...Yup, just a few days ago I was cleaning out the garage and found the "Programming in assembly language on the IBM 1620". I thought about tossing it, and instead put it back on the shelf.
shhhhh! My wife's pet rat 'Baby' will hear you!!!Cause you never know when that might be handy... like to throw at a rat...
