What caps are supposed to go in the duocast?
Harry Klippton
Searching mouser using their filters for 330uf radial electrolytic caps that are 35v or above and 5mm diameter, and it says "please modify your search so that it returns results." So what caps are supposed to go in there? Surely you had a specific cap in mind when you laid this out @PedalPCB?
You give me far too much credit, I'm flattered. :ROFLMAO:
Ignore the 5mm criteria, that field is automatically filled and needs to be changed.
You can squeeze a 10mm in there. I need to update the doc and the lead spacing so it's a bit easier to install.
might have also been "in stock" selected, I've had it admit a component once existed but the stock was gone, sold out or no longer made.
I put c10 on the back of the board. It's not as bad as the simulcast. There's no hope for that one. I had a different issue with the duocast and was contemplating getting a new board and the "right" caps but since that's not an option, I'm going with the fugly fix
