People talk about matching transistors, but what do they mean?
There are a few instances in pedal circuits where matching transistor parameters to each other or to circuit requirements is essential for proper performance.
1. FET-based Phase-Shifters
Many Phase Shifters used JFETs as voltage-controlled resistors. The Phase 90 is a prime example. This schematic is from electrosmash.com. They have a very good explanation of how Phase-Shifters work, so I won't repeat all that here. They link to an article by R. G. Keen on JFET matching that is well worth reading.
The transistor parameter that requires matching is the JFETs' Vp, the pinch-off voltage. Vp varies widely for the same part number. The trimmer resistor is there to adjust for the JFET's Vp, but there are four JFETs and only one trimmer, so matching Vp between the JFETs is essential for the circuit to function. How closely should they be matched? The closer the better; if you get all four withing 0.1V you're going to have a great Phase-Shifter. Get beyond 0.5V or so and it will be crap. If there is one take-away here it is that unless you buy a matched set, you will need to buy at least 5x as many as you need and test them yourself to end up with a good matched set.
2. Differential-transistor octave circuits
There are five types of octave-up circuits on PedalPCB. One of those circuits uses a pair of transistors to perform frequency doubling. An example is the Propolis.
Q3 and Q4 act as a full-wave rectifier, switching between two copies of the signal that are 180° out of phase. Without getting into the finer details of how or why this works, suffice it to say the two copies need to be identical for the strongest octave-up content. for that to happen, Q3 & Q4 need to be matched for Vbe so that they turn on and off symmetrically. In addition, some other parts need to be matched, specifically R7 & R8, R9 & R14, R10 & R13. If you use 1% resistors, you don't need to match them by hand. If you use 5% or 10% carbon comp resistors, get out your DMM. Also, Q2 needs to have hFE >100 so that the signals at the emitter and collector are the same amplitude.
![TMR Bumble Buzz [Propolis] sch.png TMR Bumble Buzz [Propolis] sch.png](https://forum.pedalpcb.com/data/attachments/7/7988-2fdc9f8041a7364e820eb3c8958eb316.jpg)
