joelorigo Well-known member May 10, 2020 #1 I got these mixed up. One of them is 50k and one is 5k. Is there a way I can tell which?
Robert Reverse Engineer May 10, 2020 #2 The one marked 503 is 50K. The one marked 502 is 5K. 50 is the coefficient, 3 is the power of 10 multiplier.
Dirty_Boogie Well-known member May 10, 2020 #4 Or, use your multimeter to check resistance - use the 2 outside legs.
Ratimus Active member May 10, 2020 #5 You can also measure resistance between the outer two leads if you have a multimeter. When in doubt, ohm it out! Edit: looks like I was a little slow on the trigger. Dirty_Boogie was seconds ahead of me
joelorigo Well-known member May 10, 2020 #6 In an effort to expand my knowledge I will try the multimeter Thanks!
