p_wats
Ever have one of those weeks where nothing you touch works?
After scrapping the last Arachnid board that had been working fine until I pushed it too far with more mods I decided to try again, taking what I learned to an even older Arachnid/Octagon board.
I carefully built it up and tested each stage before moving on, then when it came time to box it up I noticed that, while it worked, there was a persistent whine/high pitch sound with the wet signal. Trying to be more methodical this time, I've eliminated other variables (relay board, clock module, etc.) and am back to mostly just the old Arachnid PCB.
This circuit was boxed up and working fine for a long while before I took it out of the enclosure (maybe my first PedalPCB project)---I even recorded with it and don't ever recall this whine being there before.
Has anyone ever experienced anything similar? Thanks for any troubleshooting support for this or my last attempt!
(in the photo below the crystal and 15pf cap are not actually soldered, just there to test after I removed the clock module. The connection at R5 is to toggle internal programs. Also, the relay board is disconnected from power and I'm using gator clips on the main board to test in/out)
- The whine I'm noticing is not present on pin 1 of the FV-1, but can be heard in the circuit once it leaves the chip (Pin 28)
- It is present without anything plugged in to the input
- It does not go away when the circuit is boxed up and grounded to the enclosure
- It is still present with battery power
