Coda
I bought an amp several months ago: and Acoustic 134 (essentially a solid-state Super Reverb). I got it for next to nothing. Up until recently it has worked 100%...except every now and then the volume would drop when playing through the reverb channel. A swift tap on the top of the amp, just above the input/volume control would immediately remedy the problem. Yesterday the volume cut out completely, and no amount of hitting has brought it back. I still have the normal channel...but solid-state + no reverb =...eh. The symptoms lead me to think that there is a loose connection, probably involving the volume pot.
Any tips on working on amps? I know that tube amps are far more en vogue, especially when it comes to tinkering, but any tips would be appreciated. I plan on pulling the chassis out this weekend and checking under the hood. Hopefully a shot of CRC will fix the issue. It usually does...
