SOLVED wiper noise. different suppliers. different pedals. what am i doing wrong?
likeyeah
I'm at somewhat of a loss, and wondering what i'm missing.
I did a college search for the problem, but so far i'm still being new and stumbling around so hopefully someone can help me.
I've built 2 pedals so far, a stumble and a transcendence boost, and they both have the same quirk.
- all dirt is being generated by the amp itself, no distortion pedals on the pedalboard
- Both pedals sound as expected when engaged, (no distortion when played clean, etc)
- all pedals are on iso power, there's no hum or other issues.
both pedals exhibit wiper noise when i use the volume knobs at higher gains.
edit- it's a soft rubbing noise like a mic being dragged through fur or something.. no crackles or pops. just the sound of ...movement.
Things i've done:
original pots were amplified parts sourced, replaced with ones from i love my switches.
original electrolytic caps were 'capacitor' brand caps, replaced with nichicon and (iirc) rubycon.
original ceramic caps were 'capacitor' brand caps replaced with vishays
the only caps i didn't change were the film caps, those are kemets.
what am i missing? thanks for helping a noob.
Solution
I’d double check voltages, DC before and after the cap coming off the opamps.
Maybe check the opamps and see if they’re good? Only other weird thought is bad jacks or bad cable - or something intermittently weird
When you say wiper noise on the volume, you’re meaning the pedal volume/boost, correct?
I was thinking dc leaking to the wiper, but I’m wondering if you’re having issues I sometimes have: forgetting to turn the potentiometer all the way off or on to solder, which causes a burn/jump in the track.
If it’s just with your guitar potentiometer volume, then it might be something with something else. Hopefully that’s a start.
yes i'm talking about the pedals. its tuner --> stumble + what's in its loop --> transcendence --> amp.
i've tested each pedal by itself also.
i remembered to do this with the replacement parts, was wondering the same, so i'd just gotten new ones from a different place... also noted the three second heat window on the data sheet the second time around.. so i just replaced all three out of hand.. no change.
the noise is smooth in the sweep.. so it doesn't sound like there's any hot spots for lack of a better way of conveying it.
how do i troubleshoot dc leakage in these circuits? thank you!
Solution
this got me thinking, so i scrubbed the pc board with iso again because i forgot to clean it up after swapping the caps and pots for the new ones.
it also dawned on me that when one clearcoats a finish.. wherever the clear paint hits, will be painted. even if it's just overspray. so i sanded the inside of the case around all the holes and also scraped the paint out of the screw holes in the bottom cover just to cover the bases..
the wiper noise is finally gone. Thanks to everyones input.. I'm going to try this on the other pedal too. it's probably the same issue.
