Hi
I'm doing a dual pcb pedal, and im trying to incorporate this board into it to allow me to decide which pedal comes first in the chain. The setup is 2 pcb's each wired with there own true bypass footswitch, and then both in's and outs running to the order switcher, and then the order switchers in and out running to the jacks.
I thought it should be pretty straight forward. Input and output of the order switcher to respected jacks, S1 to the first pcb's footswitch input, and S2 to the first pcb's output, and so on for S2 and R2.
So far, I can get a bypassed signal through the pedal, but I cant get the effect to come through it. I've rewired both pcb's footswitches just in case i shorted one out, but to no avail. I should try and run each pcb on there own to make sure everything is ok, but its such a mess in the inclosure that it would be a real pain to try that. Anyone have any ideas?
Thanks!
Thanks!
