Dan0h
The protoboard, thank you again Gift gods, has me thinking.
Since pots are just tweakable resistors, and since 80% of the pedals I like have that magic spot that once dialed in never changes. It would be cool to rebuild a handful of pedals, measuring the pots resistance and using a resistor in place, into a single wood enclosure pedal board with just a volume/level knob and FS per pcb. I’ve seen a lot of you gurus make these custom monster multi boards so the idea is not original at all, what ideas really are anymore… but I think it would be pretty cool and would be a wood project and a pedal project to keep my mind busy for a while. It would have a section to drop one or two normal pedals in because you gotta be able to keep it fresh with the pedal of the month but the basic foundation would be there and I would have all my favorites on tap.
Any tips on noise issues having multiple boards strung together in the same enclosure? Probably should line it with some sort of foil/metal to keep the radio stations out?
Just brainstorming. I might have just enough Walnut left to pull this off and give my cab build a little brother.
