Hi all,
Third pedal build so still very much a beginner but this was first with issues.
Lint strands have been blow off
- Bypass is working when pedal is off but there is no sound when I turn the pedal on.
- Used audio signal tracer and the input signal only makes it to R2, everything after isn't picking anything up.
- C2 and Q1 have continuity with connecting point of R2
- Checked for any visible shorts but did not remove components
- Resoldered a few connections that I assumed may have been weak
- I'm using a J176-D74Z in place of PF5102 at Q1
- Sound very quietly came from post-R2 components and loudly to first few when output jack ground was touching same ground as the signal tracer.
