Popnfreshbass
So my woodpecker build has been my first non functioning pedal. I get a signal in bypass mode, and when effect is engaged. But it’s just a dry signal. Level knob works as intended, depth knob is a volume knob but in reverse, and the switch and rate have no effect.
After some digging, transistors seem to be an issue with this pedal. I used a j201 for q1, a 2n5089 for q2, and a 2n6027 for q3.
the 201 is the smd adapter board from pedalpcb so no issue there. (Drain is reading 7.5v) although this is my first time using not the exact part. But after some reading it seemed like this was an ok sub for the pf5102.
The other 2 transistors were sourced from banzai music. My first time ordering from them. It looks like the 2n6027 may be a fake/ebay one as it matches the pics I’ve seen posted on here. I bought a few other odds n end from them(belton brick, tm011 transformer) should I be worried?
I have a basic understanding of electricity, but have no idea how to test if a transistor is fake or working as intended or if my meter could even do it… any help is appreciated.
ibb.co
ibb.co
ibb.co
B190-C91-F-DDF0-4217-B38-B-EDA5-AAF689-E5 hosted at ImgBB
Image B190-C91-F-DDF0-4217-B38-B-EDA5-AAF689-E5 hosted on ImgBB
843-CB06-B-35-B4-434-C-933-D-73-E4092-DD506 hosted at ImgBB
Image 843-CB06-B-35-B4-434-C-933-D-73-E4092-DD506 hosted on ImgBB
926-E747-B-8-A62-4848-AC07-49-CA333-DBF3-B hosted at ImgBB
Image 926-E747-B-8-A62-4848-AC07-49-CA333-DBF3-B hosted on ImgBB
