falco_femoralis
I've been wanting to put this together for a while and I've finally found the time now that my big car project is done.
This is my cheap $79 SX strat. It's sentimental to me. A while ago I put a set of Fender Pure Vintage 59 pickups in it, which are not noise cancelling in the in between positions, so I copper taped the inside. Made no difference.
It's not the exact same shape as a Fender so I had to make some alterations to the new pickguard
I got this file set on amazon a couple years ago. It's one of those things you don't think you're going to use but it's very nice to have when you need it
All wired up, except for one thing. Can you spot the mistake?
And here we are. I wanted to add a humbucker in the bridge so the guitar would have some kind of hum cancelling. The humbucker is coil tapped via a push/push pot so pos 2 can be hum cancelling as well. Normally I would use a super switch to get cool auto coil tap in pos 2 and 4, but I wanted to use the original switch that came with the guitar in this case.
