droneshotfpv
@music6000 , excellent build! I just finished building this pedal, and I have a question for you (or anyone else who can chime in). When looking at the PCB during the testing phase (after completing the build), I wanted to watch the Clipping LED's light up. I switched to that mode, and as I strum the guitar, 2 of them lit up, but the 3rd didn't. I switched around, switched gain settings, switched the rotary, boost, etc. 3rd one didn't like at all (unless it was SO faint I couldn't see it). I thought maybe I damaged the LED somehow, so I tested with my DMM, and it lit up perfectly.
Is this normal? Looking top down on the PCB, it's the furthest left of the 3.
Second thing is, on yours, when you flip the bright switch, is there a noticeable difference? For me, it's almost as if the bright switch does absolutely nothing at all when flipped. I tried at various volumes and combinations to see if it was working, and for me, I didn't hear a single difference when flipped.
Here is the weird part, as far as I can tell, the pedal is working great, and sounds great, albeit with what I would consider a "need for more volume". It drives and breaks up well, sounds like I would expect when turning the gain up, but the volume seems to bottom out at some point (around 1:00) and doesn't add anymore volume after that.
What would you recommend I look for, if anything?
Thanks for your time! If I need to post this in a general area, I will.
