Old School, Strummed a Chord & tuned each Trimmer by ear.
This is what I have used for years, Pedal PCB Footswitch wiring is correct & PCB matches the Footswitch breakout Board.Hey! Having issues with mine, followed the wiring but I’m having ground issues. The switch I wired is wired differently than yours, why so?
The one in the build instructions looks different to yours, the last row Is jumped, safe the middle one which is jumped with the input prong.This is what I have used for years, Pedal PCB Footswitch wiring is correct & PCB matches the Footswitch breakout Board.
This Pedal sounds Great but has to be with Genuine J201's that are in Spec with IDSS & VGS.
Did you use the Siiliconix J201's I suggested for your Final build?I agree. I couldn't get it work with the substitutes. I wasn't expecting any better results from genuine J201, but I was completely wrong.
Yes I did. Thanks!Did you use the Siiliconix J201's I suggested for your Final build?
