X
Nice looking build! Glad that adjusting the trimmers by ear unlocked the tone you were looking for.
Hey! Having issues with mine, followed the wiring but I’m having ground issues. The switch I wired is wired differently than yours, why so?
I'm having issues with mine as well. Found the replacement PF5102 and J112 might be the culprit. I'm just waiting for my real 201 to show.
my j201s all work correctly, they all read well, I’m guessing the issues is the switch, got rid of the grounding. Clean sound on bypass but when I toggle it on it doesn’t work.
This is what I have used for years, Pedal PCB Footswitch wiring is correct & PCB matches the Footswitch breakout Board.
The one in the build instructions looks different to yours, the last row Is jumped, safe the middle one which is jumped with the input prong.
There is more than one way to wire a 3PDT stompswitch and get the same results. What Music6000 did is equivalent to the wiring diagram in the Build Docs.
It's subjective, but lower Vp will give more gain. With trimpots that large, any J201 that's in-spec should work. I'd use the lowest Vp parts for Q1, Q3 & Q6 because they have the smallest source resistors.
I knew you'd be right on it, thanks.
So (asking for a friend... ;) ) what do I measure to find out if my smd J201 that I banged already in there are a good choice and how would I (well my friend...) improve the biasing on that circuit?
I'll measure later on to confirm but from memory I set em all to 4.5 volt. I shall try also to tweak and listen a bit more, so far I'm not overwhelmed with it. Will post my results back here.
