Chrisq206
I just finished doing my best to check the resistor codes, and cap values
The pedal works, but the phasing is weak compared to a newer MXR Phase 90 I have.
I would understand if it was supposed to be more subtle than the newer unit, but this seems too subtle.
The matched 2N5952 transistors from Pedal Parts, so hope they’re good.
I have a Peak Atlas in case you recommend I pull them out and test them
Thank you for any help you can give
