Daaaammmn. That’s sharp, nice job. I wish I had your woodworking skills.
Sweet! I worked at ARP when the 2600 was in production and the employee studio had a couple of them for our after work amusement. I didn't get to work on the 2600 line much but I did build up a couple of the 2500 wing panels, which I unfortunately never got to play through. They weren't the ones used in Close Encounters, but it was right around the time that movie came out, maybe not all that coincidentally.*Not pedal-related, but I figure I ought to share what I've done with the help of my winnings.
My Scrap-Wood 2600 Synthesizer:
I'd been storing this scrap of plywood for about 5 years hoping I'd be able to use it one day- I had to shrink an aspect of the design about 4mm in order to use it, but it worked out great in the end. The pine was just some old nasty 2x4 planed down:
This would've been a nightmare without my router table. I used it to shape those channels in the pine and also to trim the two plywood sides flush with each other:
A test fit before glue:
Here it is all glued and finished with India ink (mixed 1/10 = ink/water) and boiled linseed oil:
Finally, the money shot..no pun intended:
Some of the ink bled into the pine a bit- I should've been more careful brushing around my masking tape job.
The wires inside could use some attention and the rear needs an aluminum plate but it will function like this until I find the material.
So what is it and why would I do this?
I'm a huge fan of early synthesizer sounds in sci-fi sound tracks and rock music, so when I stumbled across a little documentary (below) that explains many of those sounds were made on the Arp 2600 modular synthesizer, I couldn't stop thinking about it.
I was (and still am) uncomfortably jealous of anyone who possesses knowledge required to operate one of these instruments and I decided I ought to attempt learning at any cost.
Add in some modern modular functions and effects, and now the possibilities are even more endless.
So far, I've discovered numerous great mono-synth tones, many, many flavors of laser rifle, and a couple of the words R2D2 says when he's swearing at C3P0.
Compared to the potential of this instrument, I know absolutely nothing.. but that's where you start.
@fig thanks so much for the help!
This is awesome*Not pedal-related, but I figure I ought to share what I've done with the help of my winnings.
That's a really neat job to have had- I didn't meet the prerequisite of being born yet so I wasn't considered for the position.Sweet! I worked at ARP when the 2600 was in production and the employee studio had a couple of them for our after work amusement. I didn't get to work on the 2600 line much but I did build up a couple of the 2500 wing panels, which I unfortunately never got to play through. They weren't the ones used in Close Encounters, but it was right around the time that movie came out, maybe not all that coincidentally.
I’m a noise maker as well…Thanks for all the kind words about my synth build, pedal friends-
part of me was expecting to be banished from the forum for treason/turn-coat-ery!
Bought a small case this summer, but looking to build some diy modules, this gives me idea for a larger angles 7u case!Thanks for all the kind words about my synth build, pedal friends-
That’s a killer synth you made man!!!
Great job!!!
That's next-level stuff...but that's just how you roll![]()
That is seriously one of the coolest project builds I've ever seen. Bravo sir
Well I got this on the other sideWhoa- that's an impressive collection!
I really dig the lighting.
Thanks Tim-
Your contest played a big part in helping me pull the $ trigger!
Flattery??
I'll take it.
Thank you very much, SillyOctopuss!
It's quite a virus, isn't it..
I'd highly recommend an angled case over a flat table-top set-up.
I modeled my design after the arcade cabinets and pinball machines that I would see at the pizzeria as a kid, but I'm really pleased with the ergonomics of the tall, tilted design- It's really nice to be able to see what I'm doing while standing up straight, rather than hours and hours of neck-half-bent looking downward at the synth.
It looks like @K Pedals may play while seated with all the racks set up to face directly at them- I imagine it's quite comfortable, very wise.
