Speed up the horizontal sweep and let's get a closer look at the HF noise. Is this that MOSFET circuit you showed me on Sat?Question..could that distortion in the CH1 peak be parasitic oscillation....or is it just likely plain noise from the breadboard?
Interesting! Jubal81 loves him some JFETs! What resistances did you end up with on the trimmers?After going through a few ideas, I decided I wanted to keep my design as close to the original PCB as possible.
Hey, I always had big love for JFETs and Muffs - so, porque no los dos?
Wasn't sure what to expect, but this thing is Sofa King badass. The noise is also extraordinarily low - like eerily low, even at full gain.
Calling it the Fuzzduster for now. Will probably make a few tweaks, but it's already really close.
2SK880 JFETs with the source resistor trimmed to get 5.5V on the drain. Other 'high gain' JFETs should work just as well. The only deviations from the stock PCB are adding two extra caps - a source bypass on the input stage and a treble bleed on the gain pot.
They're all between 1.8K and 2.4K.Interesting! Jubal81 loves him some JFETs! What resistances did you end up with on the trimmers?
Chuck, was a little too eager (or perhaps lazy) to get this up before double checking everything. The resistor in question is 22k.Two more questions for BtR:
- What's the value of that mystery resistor connected to the high-side of the TONE pot?
- It's customary to put a capacitor between pin 2 of the TONE pot and the next transistor's bias network. Since your circuit doesn't have one, what happens to that transistor's bias when you turn the TONE pot?
For many of these circuits you can simply dial back your guitar's volume pot. I tend to dime MOST of my dirt pedals anyways, but there are a few exceptions such as a Rat.You're not a fan of Gain controls, are you?
That's sweet!Hey, I always had big love for JFETs and Muffs - so, porque no los dos?
There's your problem....try a breadboard!Back to the drawing board.
You just solved an issue on something else for me!I forgot that electricity goes BOTH ways.
Will do. No it's just a fetzer [but may end up with the MOSFET]. It seems I have a FETish as well.Speed up the horizontal sweep and let's get a closer look at the HF noise. Is this that MOSFET circuit you showed me on Sat?
I could use some free time if you’ve got any laying around.That's sweet!
btw, if anyone needs any odd bits for their entry, hit me up. I also have a few of the mini protoboards left if that is a barrier to someone's groovy entry. Free to good homes, and I'll throw in the hardware to build it. Solder it yourself though![]()
I spend most of that misnomer here too.I could use some free time if you’ve got any laying around.
Only if @fig sends you one, LOL
BtR has got me all worked up now. I had to have a dose of fetzer.
A 2N5952 with a Vgs-off of -2.2V and Idss of 5.71mA.
The source is at 1.1VDC and the drain @ 4.5VDC.
The scope pic says the CH2 signal is 1.67Ap-p. How can that be right?
