So I had bought the Procrastinator about three years ago while I was in school for electrical engineering, and I was unable to get it to work. After much troubleshooting it still didnt work. I recently found it again and decided to not use sockets on the transistors, but while desoldering the sockets I broken some soldering pads, so I ordered a brand-new Procrastinator PCB and just started from scratch.
This time I tested all my transistors and the JFET to ensure they work and to 100% make sure, while also double checking with the datasheets, that the pins were correct. With also looking at the PCB itself and following the traces while double checking with the schematic, the 2SK30A is in-fact backwards on the PCB outline print. Okay, I got that sorted out.
Now I double checked that each resistor and cap were the right value and that the electrolytics were in the right polarity on the PCB. I soldered in the transistors with extreme care and only hit them quick to get the solder on, nice clean and shinny solder joint (no cold joints anywhere).
I decided to still use a socket for the op-amp tho, but ensured that the connections where good.
I even bought the little PCB 3PDT Breakout Board for the switch to furthermore rid of potential errors.
I have also put some plastic sheeting on the bottom of the PCB so no shorts happen when it is against the pots.
So, it's all built and I plug it in. The LED turns on just fine, but there is no sound. I actually realized if I turn the Sensitivity knob all the way up and play really hard I get some stuttering sound from my amp. Im going to double check the op-amp and pots, but they havnt been misused at all.
Wondering if anyone did this build and what they have noticed or anything. Any help would be great!
Thank you for reading my dumb of a post! I tried to give as much detail as I can haha.
