SOLVED XC Phase: No Phase Effect
Edenspace
Just boxed up my XC Phase and I am not getting any kind of phaser sound out of it. The only thing I get when engaging the pedal and messing with the controls is a bit of boost and a coloration of the signal. Unfortunately did not get a picture of the bottom before boxing but here is a picture of it in the enclosure. After reading some of the other troubleshooting threads I tried to adjust the trim and broke the little plastic top off accidentally (can still adjust with tiny screwdriver). After turning the trim pot either way in small increments, I have noticed no phase effect but sometimes get a consistent ticking noise. One other thing, instead of using On-On SPDT switches, I used On-Off-On on accident. Don't know if this would cause an issue as well. Any help is appreciated! image0.jpeg
Are all your transistor legs making full contact with their sockets? I find that occasionally one of the legs doesn't make contact, and if I put pressure on the transistor, suddenly everything works. Just something to test.
