Solved-Madbean Archibald
chongmagic
I know I should post this in the Mad Bean forums, but I am having issues posting the pictures there I will have to resize them when I get home this evening. I built the Archibald pedal with a 12AX7 tube. When I power it on via 9v or 12v, the voltage just steadily drops. I am guessing it could be the voltage regulator. I just wanted to post a quick pic to see if anything stands out. Thank you all in advance.
What power supply are you using. In the build doc it tells you the amperage for the ps. trust me, It wont fire up right without the proper power.
I have this one here.
A cheap one I keep out at the bench. I will try the 500ma output and see if that makes a difference. Should have read the build doc more closely.
Just finished my Archibald yesterday. Bit of a tricky one.
First, check your solder joints. Looks like a couple off the switch need a bit of love.
Second, check the DIP settings. I had to turn on the buffer on mine to get it to work right.
Third, check the orientation of the tube PCB. That one threw me and I got it wrong.
