Adobe Illustrator Replacement Suggestions?
Bio77
I have been using the same copy of AI CS3 for years now. I am really familiar with this software and really like it. However, I have stoped updating my mac desktop for several years now for fear of loosing access to my AI (I lost it on my laptop a few years back after an update).
Anyway, I refuse to participate in the Adobe subscription BS, so, it's time to switch to something else. I'm looking for some recommendations of comparable software from people who are familiar with AI. Also, I'm looking for advice on how to convert and store all my existing AI files into something that I can access in the new software before I take the plunge. Suggestions would be much appreciated!
Affinity’s suite is the go-to non-subscription Adobe alternative. It has some serious oversights—but you can typically relearn your workflow within their environment pretty quickly. There are some frustrating aspects of it, but the non-subscription ownership model made it a clear choice for me.
I’m not at my machine right now, but I’m pretty confident it has no problem importing psd/ai files.
I used CS3 on a laptop until I drove it into the ground. It was on a first gen intel MacBook Pro (2006) that I used until 2015 or so.
Has Affinity sorted out the compatibility issues with Illustrator? Some folks have been having trouble with Tayda UV printing because Illustrator (used at Tayda) sometimes collapses the layer structure of pdfs created in Affinity.
I’ve never once had an issue with tayda printing a pdf export from affinity. If you follow the instructions and are careful with your file preparation (particularly spot colors and overlap), you should be fine. I think the issue is arising with people not used to print file prep exporting things that tayda cannot realistically be expected to support.
That being said, there are odd issues with the way affinity handles layer exports that make cleanup in illustrator nearly impossible. Since I don’t think that that adobe workflow compatibility is high on their to-do list, I don’t think that that will change any time soon.
Thanks everyone. I'll give these a try. It just dawned on me that I should probably try these out before I commit and boot my AI.
I use photoshop cc2017, works great. I don't know if you can do vector graphics with it though.
I tried Inkscape and was super bummed to find out that it’s not compatible with AI format. There is some weird scaling happening because apparently AI assumes a certain dpi and Inkscape a different one and I haven’t figured out a way to fix it (not even by manually editing the file). I’m sure Adobe doesn’t want the two to be compatible to avoid losing customers…
I can wholeheartedly recommended Corel Draw but it’s not cheap. I wrangled a license from a friend of mine or else I probably would not have splurged on it.
I find it to be really great and it has the most robust and powerful dimensioning tool I’ve seen in all the programs I tried, which is really useful because I not only use it for UV graphics, but also to plot out how hardware and boards will fit in an enclosure, as well as marking off Tayda Drill coordinates.
It ain’t cheap but it’s super powerful.
I just bought this after asking the seller if it was rentware (no) and if it could output AI or PDF (yes). It's the educational version of Corel 2014. Now, real students of course want THE NEW version, so this is basically unsellable to it's target group! And in the end, aren't we all students of life?
This is in Australian dollars, in US it comes out to $61.53 + $17.10 shipping. My current student version was 2003, and still works fine but it has a few bugs.
The same seller has a even lower priced Corel x6 as well as several other software packages, something called Corel PDF fusion, which sounds like it might also qualify, but I'm saving my $$ for a RIC 620 as soon as it's available later this year.
edited: forgot to mention I can put it on THREE computers, not just one!!!!
I am going to try out Vectornator on my iPad.
Seems to get good reviews.
I usually use CorelDRAW on PC for most of my vector stuff.
I have no experience with Illustrator, or any of that stuff, but Ive done some graphics on the iPad with Vectornator and I’m really impressed with it. Especially since it’s free! I paid to download Procreate since that was also highly recommended, but I ended up doing everything in Vectornator.
@Oh_Discordia!
@Oh_Discordia!
That's good to know! Excited to check it out.
One thing I found out Corel does is import pdfs as curves (vectors) perfectly. Makes it really easy to manipulate art from drill templates.
great info. ive been looking for a program for windows that can do vector graphics that wont blowout my already extremely low pedal building budget. im going to try and find a cheap old copy of corel draw educational version. i dont think vectornator is available on windows yet
or maybe an old used ipad would be cheaper and just get vectornator
It’s definitely optimized for use with the Apple Pencil, or equivalent. I don’t think it would be as nice to use with just your fingers, so that’s another expense to consider.
