This is one FAB pedal!
I cannot begin to thank @SYLV9ST9R enough for making my vision COME TOGETHER.The pictures offer no justice for a gorgeous UV print. The gradient schematic of the pedal makes a beautiful backdrop. Hey, that guy looks familiar.....
I used pin headers to connect the foot switch boards to the main pcb. [ extra zen ]
This pedal absolutely delivers the goods, with tons of headroom on tap and trimmable ranges for boost, bass, and trebles. The breakup is smooth and stretched.
If clean to mean is in your wheelhouse, then you should probably build this.
They seemed fine but I didn't bury the pots when I played through it.Most excellent!
Are you getting much noise from those 2N2222A's?
That's Walter White, correct?
I used my Pharmacist on bass at my regular bass jam/rehearsal/writing session and it hummed quite noticeably. I socketed the transistors so I'm planning on trying a few different NPN BJTs to see if that helps. I have some 2N3904s that are in the exact same gain range (200-ish), and various others that are higher gain.Are you getting much noise from those 2N2222A's?
This line has been stuck in my head for a few days now. I am always up for a quieter signal chain since my main Strat has low output pickups and loves to pick up anything in the air.Are you getting much noise from those 2N2222A's?
I'd suggest you try 2N5089s or similar. Socketing or breaboarding gives you the opportunity to audition as many as you like.This line has been stuck in my head for a few days now. I am always up for a quieter signal chain since my main Strat has low output pickups and loves to pick up anything in the air.
Are there any recommendations on other parts to try in replacement?
Any low-mid hFE NPN BJT would be fine. 2n3904 is a usual choice.Are there any recommendations on other parts to try in replacement?
Easy to source and reliable as snot as well.Any low-mid hFE NPN BJT would be fine. 2n3904 is a usual choice.
THAT is freaking awesome Fig!! Nice work! Love the enclosureThis is one FAB pedal!
 the photo taken amongst all those different knobs look really cool too!
  the photo taken amongst all those different knobs look really cool too!It just occurred to me that if you take the hair off, it's Walter White!Glad to have helped you bring this beautiful build to life, and I love the multicolor knobs.
And as I told you, bonus points for the color coordinated DC jack (+ you know, the general hotness of the guts!).
And for those who missed it earlier, here are the rejected doctors...
It just occurred to me that if you take the facial hair off this one, it’s LobotUncanny Resemblance:
				The classic jazz band setting. It’s how you set the pedal to kick in for your solo when you don’t know the changes to Dolphin DanceGoodness gracious is that how you set the knobs on all of your pedals!?!
