Aquaticwombat
Anyone had any issues? My signal dies going into IC2. No output, swapped 072s, new socket. It's an excellent mute switch right now
You mean they aren't meltin' bricks? Misread that. Dang.I assume you are using an audio probe if you know where your signal dies? Check the part right before it for correct solder joints or a solder bridge somewhere.
Hopefully the belt on brick isn’t in too much trouble after the melting
Aaand that's the problem with mine. Nice healthy beep.
I appreciate it. I was gonna say, you can just hold my order from this am until they come in. It's not a rush. I appreciate it!I apologize! I'll make sure to send a replacement along with your order that is shipping today (assuming DHL brings them in time).
Well if they turn out to be someone other than Kelvin, being outclassed will be the least of mankind’s worries.a higher class and opted for full 4-wire Kelvin testing.
