Harry Klippton
Not Interested
You could paint white blocks to letter onto with a different color
Nailed itI finally had success also but it took a bit…
Primer, pink, clear coat, clear coat, black crackle, different clear coat, clear coat. Now i am about to start lettering and what not.
I would thin the paint down and make a wash and kind of hit the corners of the letters making a sort of shadowing effect in color. Does that makes sense?Chipping away. Filled in the letters and outlined. May need another coat of white. Still debating if I should fill in with color.
Yes and no. I can’t visualize it. Do you have an example?I would thin the paint down and make a wash and kind of hit the corners of the letters making a sort of shadowing effect in color. Does that makes sense?
So, water down the color with a drop or two to thin it out and lightly touch the edges? I think I understand now. Thanks!Playing on the horror theme, i would use the yellow to accent the word evil and then use blue to create a almost dripping effect on gnarly.
Sorry about the rough sketch, using my sons mangled markers.
Exactly, if you are using acrylics. If using enamels then use the brand thinner, it works a lot better.So, water down the color with a drop or two to thin it out and lightly touch the edges? I think I understand now. Thanks!
