What's on the workbench?
On the bench this week till the Ultimatum arrives for tracing - Stereophonic Gizmotronic Symphonic Harmonic Perambulator
Working on a commission build for a client who want a one-off build of a stereo-dual chorus with a shimmer verb follower on each channel. It will be using 4 modified GuitarPCB "Mini-Me" chorus circuits and 2 PedalPCB 'Pythagoras' project boards with custom SpinCAD Designer/SpinASM rolled FX patches. Each stereo chorus pair will tied together at the LFO so they can be independent or synchronized with both 'depth' & 'rate' mods. Each chorus section will have independent controls. The two Pythagoras boards will be synchronized under a set of dual-gang pots & patch selection actuator. The L & R outputs will be pushed thru a pair of balanced XLR driver boards.
The fun part will be finishing the rack box faceplate.
I have a Fuzzrite in the works. Trying to make it quieter. Here's a few observations:
It sounds thinner and buzzier into a clean amp, fatter into a tube amp at the edge of breakup. So much so that taking out the 22k resistor doesn't make that much of a difference whereas it's pretty big with a clean amp.
A 470pF cap from input to ground gets rid of the radio for the most part. Still noisy though.
Adding a 100r resistor in series with the input doesn't help. It does suck high end.
I went from 2N3904 with a hFE of 192 to 2x 2N3692s at 64. Slightly less gainy and trebly of course.
Adding 100r-200r resistors to the emitters to ground didn't make much of a difference.
Noise is part of the deal here. It isn't as loud as a fuzz face. It's also scooped in the mids so you have to crank the volume and live with hiss.
I tried adding the PW knob from the Fuzzolo but it didn't work. I added it to a Fuzz Face but it oscillates. I suppose the 2.2k to ground on Q2e must be there also.
More breadboarding to come.
I was setting up my rig to play around with the breadboard. It and the Auditorium were on the floor. I stepped on the Volume pot and boom, the lugs just separated. There goes a pot...
  • Sad
I guess the Schadenfreude is verified.... How can you really decide if a circuit like that is broken? :ROFLMAO:
It’s pretty easy to make heads and tails of the different controls once you play around with it a bit. Volume and tone are self explanatory. Speed is essentially the envelope of the theremin-glissando pitch, and intensity acts sort of as a blend between the ragged fuzziness, and the random envelope-controlled pitch. It’s easily my favorite PLL style pedal, and as long as you keep either the speed or intensity below 50%, you can crank the other and still get pretty controllable effects. Hitting the front end with active pickups or a clean boost tightens up the tracking and completely changes the character of the pedal in my experience. Fun without; fun with.
One of my favorite ways to get monstrous bass tones is to track with the guitardammerung on guitar at double-speed, and then slow it down to half speed to drop it an octave.
Once I get the schadenfreude board I’ll make an extensive demo video to show y’all how to get some really rad tones out of it since the guitardammerung has been a mainstay of my board since like 2014 or 2015
Yeah I get the controls, but like all PLLs, it just sounds busted.
If you turn everything down to 0 and then just adjust the volume to taste, it’s incredible as just a nicely aggressive fuzz. All controls to 10 is of course the fun and sensible choice with noisy synthy freaks like this, but this one actually has a lot more subtlety (as subtle as a big muff or Acapulco Gold, that is) than most other PLL pedals if you go mild on the controls. I think I may have just thought of the candidate for my first buff and blend builds🤔
