Hi !
Since there's no marks on clock module I have wired it following forum threads :
"The pads on the clock module are X / GND / VCC"
Left to right from components side, IC at the top (pads at the bottom, indeed!)
It seems ok as tweaking results in moduling the effects (nice!)
Well there's a problem : when pot is at minimum it's ok, but as it's value is higher I have a high "whistling" In the audio output (higher as the pot is turned) with the normal effect sound.
And it is present even In bypass if I don't reset the pot to minimum.
I changed the 4049 but same result...
Precision : IC is CD4049UBE, can't find difference in datasheet that may explain the whistle.
Someone has a clue about this?
Thx so much!
Thx so much!
