How about the Spirit Box (EQD Ghost Echo). It's a Brick plus PT2399. I've been thinking about building this and relegating my FV-1 Arachnid to non-Reverb uses. I definitely like the Belton Brick reverbs better than FV-1Well.. doubt about this. There are PT2399 chips inside and min delay for PT2399 is 30ms.
please share what you've found,
FV1 is at the end of my list because of the overall price, availability. And it requires pre-programmed EPROM.
I saw the deadend fx bbd reverbs. When I was researching them I was convinced I would build the metamorph cause it sounds great. But finding the mn3011 seems impossible.![]()
CHARONIUM
A deep cave where tonal life or death hangs in the balance. Clone board of the Last Gasp Labs Misty Cave. If atmospheric tonal adventure is your...www.deadendfx.com
What was the overdrive? Sounded great!The eagle has landed.. ES56033E from aliexpress. Five pieces for US $5.58. Delivery took 19 days.
I tested only one piece, it works, no issues.
I've breadboarded the Stalker and here's short test. Sloppy playing but I just wanted to check different knob settings.
There are 16 "riffs". 1-8 LFO off, 9-16 LFO on. 1-4 and 9-12 mix @ 12 o'clock, 5-8 and 13-16 mix @ 15 o'clock. Time setting for each group of fours: mininum, 9 o'clock, 12 o'clock, 15 o'clock.Dropbox
www.dropbox.com
I'm quite happy with the result. Now it's time to design a pcb.
Would you be willing to share your pcb layout once it's done? I'm definetely interestedThe eagle has landed.. ES56033E from aliexpress. Five pieces for US $5.58. Delivery took 19 days.
www.dropbox.com
