DGWVI
Finished this up earlier today, but have been fiddling with adding an LFO to the sample Rate pot. Wasn't able to really find a sweep or waveform I was fond of with this particular effect. With an Uber slow triangle wave, it could get a little phasery, but meh. So, in the box it goes, cold and alone.
Still need to whip up a daughterboard for the StompLFOs I just got in today, the random levels and slopes and ramp waves might be more to my liking
Only mods are swapping the direction of the pots, with the Sample Rate now being Log instead of anti-log. I find the 837 gives a much more prominent aliasing effect with maybe a slightly wider range than the 074. It also produces a lot less less oscillator whine, even with the gate trim full up it's barely audible. The circuit just seems to work and sound better with BJT inputs, just like the Colin Raffel original. I believe I used a 324 in the last one I built.
And without further ado, an enclosure color way I've never once used, and had hardly even heard of ....
Have kind of a scattered day, but I will try to work up a demo when I have time
		 . Highly recommend that one, if you're into the crushies .
