Jeff C
Jeff C here. You may be thankful or disappointed that I am not in the midst of another marathon pedal problem solving odyssey. I actually built the Transcendence Boost pedal with only one minor error that I quickly rectified. Yah. So why did I build that particular pedal? Well, as is not unusual I get a fair amount of noise on my tube amp from my blues driver and distortion pedals when I am not hitting a string. I wanted to see if I could reduce that. I first bought an inexpensive noise reduction pedal and it works to reduce the noise but I’m not that happy with how the pedals sound with it on. Maybe I just haven’t figured out the optimum settings for it. Then I read about reducing signal to noise ratio and fell for the idea that a clean boost pedal would do the trick. Hey, I’m a history major. Well, the Transcendence pedal is just as noisy. No improvement in reducing the noise floor. It boosts both the noise and the signal. Of course. I guess I shouldn’t have been surprised. So, then I read about adding a buffer at the front end of the chain to reduce noise coming from the guitar. I see PedalPCB has a C-Buffer that in theory I could just add to the boost pedal switch. Do you think this will help reduce the noise, or should I just live with the noise, like so many seem to? Any suggestions, helpful or humorous or any type of entertaining, would be most welcome.
