mywmyw
you dont hear much about this pedal. good golly it sounds good though. relatively easy build, has that zippy bright marshall kerrang, that gets fat and squishy at the top of the gain range - really makes you wanna play some high notes and go weedly weedly. my first time using on of the integrated stomp led rings from tayda:
www.taydaelectronics.com
it was tricky to wire the led ring, how do yall go about it? a female header pin of some sort seems like it would have been easier, but none of mine fit very well.
does anyone else find that the effect of the subs toggle is quite subtle?
illuminated Push Button Foot Switch 3PDT Blue Color LED
3PDT | ON-ON | Latching | Solder Lugs | Long Lasting | High Quality
