Jbanks
I built the D3lay a couple years ago, which runs on a FV-1 platform. I swap out various EEPROM’s. The signal is always very quiet when maxed out volume regardless of the wet/dry mix value.
I later built the USB version of the FV-1. I noticed the level problem is totally solved now and I no longer have level loss.
I’m building a reverb for a friend and want to use this Radium Springs Reverb chip settings.
Does anyone know if the FV-1 USB PCB is the only one that has fixed the volume issue. It’s currently sold out. If I buy one of the reverb PCB that run FV-1, have people had issues with the level? Not sure how long the wait will be for the USB version to come back.
thanks
thanks
