Fuzzonaut
This is what the mastermind behind Dunwich Amps did to the Boss ODB-3 circuit, which means tweaking/changing stuff and adding options.
The result is an incredibly versatile bass dirt box.
A ton of options EQ wise, what you can do with the mids is spectacular I think ... and then a clean blend with a lowpass filter on it. I doubled up on that filter cap because stock, the filter is very, very subtle. There are separate gains for the clean path and the OD, labelled simply CLEAN/OD.
What the BYP switch actually bypasses is still beyond me, I stared at the schematic for a while and then gave up. It's also an "EQ thing" though.
Graphics "borrowed" from a (famous) guy that grew up in the same place as I did.
